Hello everyone. I am an illustrator and I mostly draw black and white inked drawings. Yesterday, I tried to import one of my drawing to engrave it on wood and it worked pretty well. Then I tried with a second one and I got an error message while uploading.
It’s not a Glowforge problem since all other designs work.
Can it be the size ? Or too many elements ? (If yes is there a way to make it smaller or simpler ?)
Maybe the pdf format ? Files are in pdf but are vectorized via Illustrator and they kept the vector settings.
I have tried several things but they didn’t work. If anyone has an idea
Edit : Solutions have been found. Thank you all so much
Edit - I was able to get it to upload, but it took several minutes to process before rendering.
Edit #2 - the largest node count I have previously been able to upload was 38,000. Couldn’t go higher than that. I had to simplify the file to reduce it down from much higher to get it to work. Your file has close to 40,000, so if you can simplify it just a little, you should be OK.
This forum section is for opening a support ticket, just FYI.
That’s what it is called in Inkscape, so I suspect it is the same. You should have settings to control how “aggressive” it is so that it doesn’t impact the shapes significantly.
For that second one that’s giving you issues, since you want to engrave and not cut - @shop’s rasterize advice would be the fastest way, retain the most image detail and avoid unexpected unengraved areas due to any possible overlapping shapes.
Your artwork is beautiful! So I’d recommend you delete your files in your first post so others can’t download it and use it for their own ends ( I would be tempted…)
Well done, and good luck - you’ll figure it out no doubt!
Thank you everyone for all the advices. For now I have just tried to simplify it via the option in Illustrator. It still took time but worked very well. Will try all your other advices and see which one is the best.
That looks great. Looking forward to seeing your other drawing too. You will find that the glow forge can engrave LOTs of materials that will look great with your designs.
