What is everyone using to get good results when doing large etches on clear acrylic?
I had a large etch to do, and HD etch said it would take 5 HOURS. Naturally, I’m not going to do that, so I reduced it to SD etch which only took one hour. All said and done, I could live with the lines, but the etch was inconsistent across the entire image, so it almost looks lenticular. Not the look I am looking for. Is there another way to get a clean, consistent etch across the acrylic to be more like a frosted glass? This etch went half the depth of the acrylic, and not really what I need.
Also test the LPI settings–often less power, higher LPI gets better result–alas, not a faster method, though. As was suggested, run some small tests to find what setting you like best…
