I saw this posted on Facebook: http://www.instructables.com/id/Fume-Coffin-Laser-Cutter-Exhaust-Vent-Filter/
You may be able to use the same principles (an external blower + baffles) to quiet down the exhaust noise.
How about acoustical tile then?
Or hang vertical panels of egg crate foam from the ceiling. You could arrange them so they form a paintball or laser tag obstacle field. LOL.
Thatās likely the reason - using aluminum pipes instead of the included exhaust will dramatically increase the volume of the sound.
I apologize for any misunderstanding or confusion, the aluminum piping Iām talking about is the flexpipe that came with it.
As shown here:
My concern is that the internal part of the insulated may not react well will the exhaust fumes/gases/materials and it is cheaper to replace the 4" dryer flex (and gives more damping capacity by multiple layers of material).
There is that.
Ah! Sorry I misunderstood.
@dan, how does the noise of the unit with & without the GF filter compare?
The noise without varies tremendously depending on how you position your exhaust vent, so itās hard to say - can be louder or quieter, depending.
So I added the filter partially because it was sold as an odour solution inside a common office environment. But obviously if the thing sounds like a jumbo jet it will be unsuitable for an office environment.
Q1. Is the filtered GF deemed suitable for a typical open plan office environment?
Q2. Are there any dba specs?
Looked at old posts to see whether you were close to a production or pre-release unit so that you could at least hear the Basic unit. South Africa? yeah, thatās not going to work. Sorry.
I am guessing the noise would be loud enough to be irritating in a shared office. Similar to a vacuum cleaner. It would depend on how often it is used and the tolerance of the office members.
We use it in an open office plan environment - itās in the vacuum level of noise range. No dba specs, since it depends entirely on the speed at which the fans are run. That is one of the last system tuning tasks before we ship them (and will depend on things like materials being used etc).
in fairness, though, i think you guys probably make allowances automatically for laser noise
I have to admit, thatās a bit disappointing.
I plan to use our GF in the office next to the 3D printers. But the neighbours would want to know why we keep vacuumingā¦
I guess the engineering challenge is the noise created by drawing air through the filter. I asked before about having extract together with the filter. Perhaps there could be a future solution where there is a slim filter on the machine with an extraction duct where we could place the fan outside. It would not solve the problem completely but it might help. Or, even better, have a complete filter unit fixed to an external wall perhaps? There might be a fire hazard here, I donāt know.
Perhaps we coud build an attenuation box for it. But that wonāt be easy.
Thanks @rpegg, yeah weāre out of orbit hereā¦
really? iāve lived in some thin-walled places but i donāt think something that sounds like a vacuum would bother my neighbors all the time.
In my experience as an architect I have found that sound is the single most perpetuating issue with respect to adjacent tenancies in both residential and office environments.
The other issue is of course working with vacuum in the room.
Sound is a challenge.
i donāt disagree, itās just a lot of people seem to be posting about freaking out and disturbing the neighbors, but no one has bothered to ask the neighbors if itās a problem. all iām saying is to start there before anyone goes and spends a substantial sum in an attempt to abate the noise.
This might be because noise is relatively new information. The marketing of the filter unit is that it allows users the benefit of using their GF on a desk right in their office. And itās well designed so that it can be proudly used in an office.
Now that more people are receiving their units, the sound issue seems to be surfacing.
We have 2 3D printers in the office and their noise levels are such that we can run them simultaneously without causing a nuisance.
If one uses the GF as infrequently as oneās vacuum cleaner, it may not be a problem. But we plan to use it a lot. GF are still fine-tuning noise levels apparently and have not published figures, but if the unit is too noisy, weāll have to find a different home for it. In that case it will not be trivial for a lot of folk here.
