I have seen some of these trompe l’oeil style engravings and wanted try one myself. It really isn’t a 3D engraving more of a 3D shadow marking.
I am happily satisfied with the quick results.
These look great!
Looks great
I have a couple of these designs I bought from Etsy - they are fun!
I read the title too fast and thought it said earrings, so I kept waiting for you to have a pic of earrings using this. lol There’s something that maybe no one has done yet. lol
I do that a lot including here ![]()
Googling about for trompe l’oeil style I found one particularly amazing
Amazing!!
Great result! Can you show the original?
I used the site https://www.imag-r.com/ which has been mentioned here before.
On an image I asked MidJourney to create.
" swamp thing, growing out of a wooden wall, wood grain, STL grayscale, high relief, 3d"
@MakerMatthew (this is the original, before imag-r)
that looks great.
and… i didn’t get anything close to the same image using your midjourney text in adobe firefly, but i AM going to steal much of that description to try to create similar style images. my results were at least visually interesting, i just need to refine my subject in a way firefly will give me better results. i guess there’s no “swamp thing” in adobe stock to draw off of.
This one looks like a happy benevolent Swamp Thing ![]()
i think it looks like a wood grinch.
Hmmm…you do get great AI results! I had not heard of Imagr until now. That looks like a great resource. Just curious, what DPI do you use in Imagr as a good level for the GF? I need to make a swamp thing for sure!
I usually use Blue Willow but it takes longer to get the right results. I would spend hours trying different prompts, even with ChatGPT enhanced prompts. I then bit the bullet and bought time on MidJourney, got the results I was looking for in two prompts.
As for Imag-r I just picked the settings in their wizard.
It was was the first time so I trying get a base reference. I think the only misstep was that I resized the image once I imported into the GFUI. It might have caused a moire effect, but it is slight.
A very key thought. I have been going nuts trying to figure a phrase for that effect, but you are still showing lighting from above. I have been saying “carved in alabaster” to lighten different and dark materials and ," cloudy, no lighting source or direction" and even vertically symmetrical where reasonable so I can flip the design and balance out the shading as this case…
Looks like the Grinch of Samhain.
I can’t even get a flat photograph to engrave! I’m astonished.
That looks great but I wanted more range of shades from black to white and so got this…
That should give you slightly more detail, and has all 256 shades of gray.
Yeah MJ has a huge lead. It’s almost time for weekly office hours, weds at 3 eastern. You should pop in, it’s always interesting.
The first half hour in particular is where David talks about the state of the company and what they’re working on.
