I saw @theroar84 's design for the beard comb and it inspired me to make a fine tooth comb. I cut it out of medium acrylic without a problem the tines are bendy. Thinking about sanding the front and back to make it more wedge like.
Anyhow here is a SVG and AI file if you want to play with it. There is a red line to add some text for engrave. I cut the outside and also cut the swirls… makes it more aerodynamic LOL. 5 inch comb.ai (84.4 KB)
It seems to turn the SVG into a two color So I zipped it as well
I cut it into walnut scrap I had sitting around, its too brittle. I widened and halved the tines and it was better, but still too brittle for just hardwood. Perhaps a veneered plywood.
