After a small problem with getting the Glowforge to connect to the WIFI, I immediatly came to the conclusion that the most important thing to learn was not really related to the laser, but simply to the design side. So like with 3D printers I picked my 2D design tool and started learning Inkscape.
As I’m documenting the working procedures, it took +/- 12 hours to get to the following amount of successful tests.
Wow, your projects look great! Looks like you have mastered the machine already. And yes, the time spent designing (if you really want your own custom design) greatly exceeds the laser run time.
Indeed, the generation is fast and easy. But that is giving a single ‘path’ and without Inkscape knowledge, it took a lot of time to get that to a laser-able file.
Not sure if this will work, but this is what I’m doing now:
