Outstanding work. I love the finished piece but the great template idea even more.
Very clever!
Genius!!!
Thanks for sharing the process behind the wall quote you made, which turned out looking absolutely perfect! I am not familiar with the term “control strips.” Is that term used in graphic design or sign making?
If you mean “command strips” thet’s a brand name for a removal wall hanging sticker: https://www.command.com/3M/en_US/command/products/ They’re designed so that if you pull up or down on them against the surface they’ll come off a painted wall without removing the paint (if you pull them straight out they’ll still take the paint/plaster with them)
Smart
Excellent work! Incredible way to avoid all sorts of potential problems.
Note you put the command strip on the wall and wait 24 hours. My tenant didn’t read the instructions. Nothing got wrecked, but she found her painting on the floor the next morning.
What a great solution to keeping it all lined up properly as you attached them to the wall! Thanks for sharing your solution.
Nicely done. This is a great example of an elegant solution.
Thank you!!! Will help considerably in future projects!
