Flexibe/resizable/non elastic mask ear savers
Here is a customized version of the EAR SAVERS, the idea is the regular EAR SAVERS are made for mask that have (ELASTIC) straps and this one is made longer to reach no(NON ELASTIC) straps as the ones you buy with sports teams and such and many homemade ones. this will allow the strap to reach the EAR SAVER without trying to stretch it to a fit.
Also, this version cut out of 1/16" Acrylic (very flexible) and it is actually twice the length of the normal EAR SAVERS. I made them long enough to reach an Adult bigger man’s head but the idea is so if it needs to be smaller all you need to do is take a pair of scissors and make a curved cut on either or both ends to shorten it to fit any Adult or Child comfortably.
GOOD GLOWFORGING FRIENDS!
IMG_2688
CUT SETTINGS:
JUST SET TO MEDIUM CLEAR ACRYLIC/CUT
NOTE:
KEPT TRYING TO UPLOAD THE SVG BUT IT WILL NOT SHOW UP AFTER, ANY IDEAS?
Thank you for sharing! Most store bought masks are too tight for my face, I’ll try these out!
Nice!
What probably happened is that the svg you uploaded was there but so tiny you couldn’t see it. You will notice when you upload that numerical dimensions are shown that are in pixels and pretty small. If you add a zero at the end of each dimension it will come out big enough to see. Alternatively, you could save it in a zip file and upload that. In fact, since svg files that contain bit maps lose the bitmap when posted to Discourse, a zip is a better solution.
Where can I get the file for these?
