I am embarrassed (and have lost count) at how many times in the past 45 years I started a fire in our fireplace, without first opening the flue damper. Problem solved thanks to Bernie (my Forge). I used two pieces of acrylic – red and green (stop and go), each 3" by 5", after engraving painted with some acrylic paint (Apple Barrel, if you want to know), glued together, and then tethered to a “hanging” device with some fishing swivels. Wow, that’s a long sentence! Make your own – and keep your home smoke-free (unless your Forge’s exhaust system needs cleaning)!
Very practical!! Thanks for the share! Important reminder
An awesome idea! Thank you for sharing! Like the use of swivels!
Awesome idea thanks for sharing.
Keep Creating.
I thought this was for the Glowforge at first, until I saw the flames in the fireplace! Still applies though, and yes, I still forget to turn on the outside fan every couple of weeks
