I searched and didn’t find this exact topic. The “turn air filter on” in the advanced settings, should this we turned on, as in does this refer to the internal fan that is part of the glowforge unit, or is this in reference to the compact filter? It’s clearly much quieter with it set, but is it supposed to be
What the external air filter option does is enable or disable the loud exhaust fan in the rear left of the machine because the air filter has its own built in fan. If you do not have the external air filter attached or an adequate in line fan you should have the option disabled so the exhaust fan in the machine in on.
Basically, if you have your Glowforge hooked up to a hose hanging out a window, it should be set to OFF (no Glowforge Air filter attached). If you are using the external $900 air filter, or if you have an inline fan between your machine and the window, then you should have it set to ON (Glowforge Air filter Attached). Without using a filter or an inline fan, you must have the internal fan running which is as noisy as a small plane. If you are using a filter or inline fan, then you rely on their “sucking” ability to clear the exhaust from your machine and they are usually exponentially quieter than the internal fan.
i can’t turn off my internal fan for whatever reason the toggle is not working. any ideas why? i have an external fan hooked up and ready to go so the toggle not working is killing me!!
I just noticed this post. Don’t know whether you have found a solution. I assume you are asking about the exhaust fan at the left rear of the machine. It should be able to be disabled by selecting the filter switch in the user interface. I don’t use a filter so I can’t offer much help. If that doesn’t work then you will need to make your own post under the Problems and Support category or email Support directly. Support only checks the P&S category. The other fan located at the lower right side of the machine is an intake fan and will always run, and cannot be disabled.
BTW: just found out you are Friends with my wife (Vlynn)
Thanks for the response! I did get things turned off- not sure if customer support did it or the new computer with more memory to run the UI- my internal fan is off and the quiet in-line fan is working great! Say hey to V for me!
