I have a simple project and from what I can tell a complicated kerf. This my third time I have used the program. Still not doing everything correctly. The other files I fixed in Illustrator.
It was built for the economy packs from Sam’s club. (And yeah, I wound up scrapping that design in favor of something a little easier to fit into the cabinet.)
This is one of the reasons I’ve learned to use the CAM module in F360. With it, you can easily adjust kerf, even down to individual features, without having to modify your model.
I have learned more about the CAM module since posting the video, so I will trying to either record another video or write something up for you today or tomorrow.
You don’t need 2 different setups, you need 2 different cutting operations. It’s a bit more complicated when the inner and outer cuts are part of the same profile (i.e. part of the same path). I have not specifically tried to do what you’re doing, so I’m not completely confident in the process. I’m playing around with some ideas to work through it.
