I know this fusion 360 tutorial is intended for a CNC router, but I thought the dynamic tab design techniques were worth passing along. It seems that it would apply to any tabbed assembly and the beauty is that if you create and use the user designed variables efficiently, you could produce a model that you could dynamically resize by just changing 2 or 3 of those variables.
While I haven’t tried this on the router or laser, I’n guessing you should just be able to create the DXF version of the laid out sketches of the product for use with the GF.
