The following percentage split was posted after the first week or so. You can be sure that the Pro/Basic split changed since that time. (By Oct 22 the Pro was up to 55%) But for the 30 day pre-order it would be close to $3000 per order. If you know what the ticker was at the time of order then you can figure out (+/- a bunch) where your order falls. For example the ticker was about $780,000 when I finished my second beer at the brewery, so my order should near #260.
