This is a label roll holder for the NETUM printer (Also, Zing, MUNBYN, Polono - basically most 4x6 thermal label printers). They are brilliant but don’t come with a holder for the labels - they charge for it!
This stand was made essentially out of strips, which could easily be scraps - nothing is longer than 12cm, or wider than 2cm. Also gave me a time to tinker with pegs!
Considering I just purchased 2 large eco-rolls of labels from Ecoenclose.com to use on my Rollo printer, this is perfect timing! Thank you for sharing the file, and saving me the time from doing it myself
I’ve used the peg style of joinery before, and it allows a little more wiggle room with material thickness. Great Job!
This is awesome! Thank you so much for the share. I think it’ll also work for a roll of sandpaper I have. I can put a rubber band across the pegs to keep the sandpaper from unrolling. Perfect solution for a problem I have been wanting to solve - you solved it for me!
