As a thank you to all the great ideas I’ve gotten from the members here (wow!) I wanted to post the rolling table/cart I made for my Glowforge and material storage.
At first I had the Glowforge on my workbench, but stacks of plywood sheets, acrylic, leather, etc. were accumulating in growing piles around my workspace. Something had to be done. These tables are built from plywood scraps and were sized to accommodate a 48x24 sheet in the bottom section. All joinery was done with a pocket-hole jig and wood glue.
All the main materials are scrap plywood. The back was flooring plywood that was really nasty with a lot of voids, Durham’s water putty and sandpaper smoothed it out. The top is a 3/4 sheet of MDF with counter top laminate glued down with contact cement. I trimmed out the MDF table top with some 3/4 walnut ripped and mitered on a table saw. Killz2 primer for the inside and back, and a few coats of Minwax satin to finish.
You can view or download the Fusion360 design (for free) here: https://a360.co/2Uo3T4W
