It is possible to make grooves with the Glowforge machine?
, or not is recommend.
Thank You
Hernan
Thank You
Hernan
Not enough information for me to go on. What type of grove, in what material?
Do you have a photo or drawing of what you want?
If I understand your question -
I have used engraving to create a channel for a sliding top to a box. It only required enough testing to get the depth and clearanceI was after.
Yes, I do it all the time.
It takes some experimenting to get the grooves cut to the depth that you want. I’ll generally run a few small test engraves with Full Power, High speed and a fairly high LPI. Then I’ll increase the LPI to take it deeper. (Make your hole a little larger than needed, deep engraves tend to load up one side with resin. Or you can scrape it out after.)
it is possible. it’s not particularly efficient and, as @jules said, it requires experimentation to get the depth you want.
Like this?
It was in the title!
I am surprised the forum software didn’t suggest the post before you submitted your question.
Thanks Markevans for the help
The grove is about 9 inches long by 1/4 wide at a depth of 1/8
Hernan
Thanks for the help
Hernan
Thanks Jules for the help
What power, speed and LPI could you use?
Hernan
Thanks for the help
Hernan
Thanks
for the help
Hernan
It depends on the material, there is no way to come up with a set of numbers that works in all cases.
But what I do when testing a new material is create a very small filled test square, about 1/2", then start with the HD engrave settings. They will probably not engrave as deeply as you want the first time, but with the next test, just increase the LPI. Try it again and see how that one does. If it gets halfway there, for the third test, use those settings and two passes. Just keep increasing the LPI and the number of passes until you get it deep enough.
Okay, I undersatnd now and @Jules has the answer above. Good luck with your project.
For every new material I make one of these…
It can be used even if all there is, is a single 3x12 piece of wood, and it would not do to use up the whole piece of wood to know what the settings should be. That can inform me of the settings needed and how prone to burning that wood is.
