I’m trying to set up multiple engravings and having to set each one on the backs of an already engraved set of items. Everytime I get them set…something goes wrong. It locks up or it won’t finish the “prep”…once it gave me an error.
IS there a hickup going on? Do I have intermittent internet connection or am I just slow today?
It kinda sounds like WiFi issues to me. If I were you I would follow the advice given by Glowforge staff in a recent similar posting (I’ve pasted it below). If that doesn’t help, you might want to post your issue in Problems & Support.
I’m so sorry for the trouble.
Turn off the computer, phone, or tablet that you’re using
Turn off your Glowforge
Unplug your modem
Unplug your Wi-Fi access point
Wait one minute, then plug everything back in and turn them back on
Improve the signal path between your Glowforge and your Wi-Fi access point
Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
Relocate your Wi-Fi access point closer to your Glowforge
Move your Glowforge closer to your Wi-Fi access point
Install a Wi-Fi range extender closer to your Glowforge
Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
Reduce electronic and Wi-Fi interference
I hope this helps. Please let us know if you’re still having trouble.
