Here is a perpetual mini calendar that I cut using some 5 x 7 scrap material (actual material used 3 x 6). It is a bit “fiddly” to put the pieces in and you only need to glue the two large pieces together.
@bwente - Question - I put the svg file directly into GF and since all the lines were the same color I had to either cut all, engrave all, or score all. So I put the file into Inkscape to change some colors so I could engrave numbers/letters and cut the lines. I found numerous 100% opacity areas. I brought them down to see what was under them, un-grouped, then there was another 100% opacity, un-grouped, etc. I know there is an easier way, but being new to all this it eluded me. Any pointers?
You might have to waste some material. I was being stingy and used the back to cut the legs. It is a bit tricky but the “tiles” shouldn’t fall through the back. If you want acrylic you would have to move the support legs from the back board.
Took me a little while to figure out why the little squares would not fall out and then realized they would never be in that area. Nice, clean, simple design. Thanks for the file.
