Help Engraving Ikea Aptitlig Cutting board
The surface of the tray is around 1.5" above the floor of the machine. It can only “print” from that height up to about .5" higher. So you need to prop your material up so that it falls in that range. You enter the height it now sits above where the tray surface would have been.
Here’s one (of many) solutions to supporting material:
