So, i have this pic, i want it to cut along the lines and engrave on the whites, but i cant get it to work, anyone who can help?
Try this:
I’ve broken out the shapes into three different pieces:
The black fill can be engraved separate from the yellow fill. The red stroke can be used as your cut line.
Your problem was that the original was a single compound shape.
Thanks so much!
BTW, if you downloaded the file already, please check that there are no red lines around the eyes. I noticed my mistake after the fact and re-uploaded a corrected version.
just got the broken one cut xD
But thanks again!
But how did you do break out the shapes?
Quickest way to do it, since it was a relatively simple compound shape, was to create a duplicate of the shape for each operation and delete the appropriate parts.
The first part is the original art, with the black fill.
The second part is a duplicate with the outer line removed, leaving just the fill for the eyes.
The third part is a duplicate with the eyes removed, leaving just the outline.
DUST PUPPY!!!
wish that comic was still being done.
