I decided to pick up some 1/4" (6mm) Hickory wood to make some extra thick coasters. I couldn’t really find any good settings on the forums, but thanks to @pubultrastar I was able to get headed in the right direction. I am happy with the engrave (Full/1000) but not sure about the cut. I had to do 3 passes at 130 to get it to cut all the way through. I also tried a few other speeds, like 200, but after 4 passes it still wasn’t cutting through. I also tried 100, but I was afraid it was going to singe.
Here is what my test piece looks like after cutting three passes at 130. (No engraving on this… as I was just trying to test the cut). Is this what I should expect for hardwood? A nice black edge? I actually like the look, and after wiping it down the char isn’t coming off and it kind of has a cool melted effect. But before I cut anything else I’d like to see if there are any suggestions.
