High Tack Recommendations
Anyone use a high tack transfer tape they would like to recommend? I’ve been using a medium one from US Cutter that just isn’t staying down on some of my pieces, causing some flames - no bueno!
This might help you:
The sanding makes a big difference. Sometimes I’m lazy when I just want to cut something quick and I mask it without sanding-huge difference whether it’s solid hardwood or plywood.
Nope. Medium has been sufficient. As stated above, surface prep and how it is applied makes all the difference.
Thx. Yeah I clean off and use a squeegee. Just want to know high tack experience from anyone that has used it.
Pretty sure @jules used it at one point? Most people use medium tack, it’s sticky enough for all but the most stubborn materials. I think it’s even a bit too sticky for acrylic.
No, I think mine was medium tack…but you do have to brayer/squeegee it down thoroughly to activate the adhesive.
The small amount I used was enough to convince me to buy a roll of medium.
It stuck to baltic birch like a stubborn price sticker, and left residue behind.
I am sure every brand is different.
See if there’s a vinyl sign shop in your area that would sell/give you a couple feet of their transfer tapes to try out. Most will be happy to. I suspect that you’ll find high tack too aggressive.
TransferRite 592U
Use a signmaker’s squeegee or a brayer.
Also, tack cloth for cleaning, especially if you sand.
Put down and peel back up a sacrificial layer of the tape to grab loose fibers and dust if you are having issues with peel-up.
Adhesive activates with pressure and sets with time: mask your material early, let it set a little.
