Ok I used a box generator and made the size box I need. I need to cut a circular hole in opposite sides. how can I design this? the hole needs to be 1 7/8 inch diameter. I have the box design saved as a PDF format. I have access to Inkscape and corel draw. Sorry if this is very basic. I have had my pro for a couple of days and made the ruler and did a couple of traces.
Does the box design software allow for SVG output? If so, then you can open up the SVG in a design program and add the circle.
Otherwise, you could make the circle file separately and upload it in the add artwork once you have opened up the PDF in the operations space. You usually can place one piece of art correct in relation to other placed art.
guess i have some homework to do. It was much easier to the in my V-Carve software for the CNC. i will need to play a bit and figure out how to handle determining exact dimensions for the circle metric vs. English ARRGH.
using corel draw I have the whole thing laid out in a pdf so i should be able to import to inkscape and save as SVG I tried to save in CD but it warned me it did not like my color choices for the lines, said they weren’t RGB colors
Don’t forget to let us know! Personally I would recommend the Inkscape route - free, powerful and lots of tutorials out there.
(Did anyone else read the title of this thread and think it was the opening of a riddle? … open the tabbed box, remove the elephant then add the circle cut out…"
Ok ran my cut today. used a box generator to design tabbed box. Imported the PDF of the box to Corel draw. I added the circles with a diameter of 1 7/8 inch. Saved the file as SVG. Imported to GF and set the cut settings, speed and power. design cut fine but my circles have a diameter of 2 inches. They gained a 1/8 of an inch in the design process. Any ideas as to what can be done to correct it other than reducing the circle size by an 1/8 in corel and hope the variance is constant.
Most of the time you have a scaling problem in an art program it comes back to how many points to an inch. If you make sure everything is handled in either mm or in all the way through the scaling problems tend to go away.
I finally seemed to get it all to work. I have made a 3.3 x 3.5 x 3.5 Bluetooth Speaker Pictures to follow. But more importantly have scratched the surface of the design process.
