How much detail can a Glowforge print well. Getting ready to download some Shutterstock vectors and want to get an idea of what vectors will work. Thanks so much.
Anything really. I engraved a phrase on a grain of rice with it.
ButâŚ
For really large sized engraves, you do NOT need a high PPI count. (Only for very small prints, because you need smaller pixel sizes to get the definition.)
So you can get away with the cheaper versions for large prints.
A lot of details. MASS amounts of details.
This is imprecise on a few levels.
First of all vectors donât have anything like dpi, so ignore that.
The bottom line is that the Glowforge can print very fine details but it depends on your settings and the material. Youâll need to test to be 100% sure but details as fine as 0.5 mm can be reliably engraved on most things, often even smaller.
As for dpi that applies to raster images and is a deeper topic. Basically you canât engrave detail that isnât in your image, so youâd need to be sure that the image is fine enough for your purposes and that the final scale of your image details doesnât exceed what your material and settings can handle.
Again that isnât really a concern with vector shapes, but itâs engraving detail 101.
All of them, I thinkâŚ
the material part is very important. some materials youâll be able to get incredible detail. others may not burn as cleanly and may not show fine detail as well (like the pine board iâm working on right now).
Oh whoopsâŚtotally missed the vector part of the equation. I generally pick up pixel images from Shutterstock.
Yeah, any size with vectors. You can scale those up or down without loss of quality.
This is very helpful.
I would be interested in what materials do better with fine details and which materials are less welcoming of fine detail.
Thanks
Well like take anodized aluminum Beautifully crisp engraves but requires full power, so the finest lines you can get arenât too thin, on the order of about 0.01â.
There are as many materials as you can think of, testing is the best way to be sure. Search the forum for examples, like if you wanted to try bone or oak or whatever just search for âoak engraveâ or âengraved rat skullâ.
Holy wow that is amazing.
Thatâs kinda hard to qualify because it all depends on your material, setting, the artwork and your ability to manipulate/adjust the artwork. Itâs also hard to know what you mean by âhow muchâ and itâs easiest to just show a few examples. ![]()
Various woods
This is about 6x8 and pretty high resolution image
About 4x6 mid-resolution
About 5x7
Things like slate wonât allow for as much detail because you arenât burning the stone away, youâre blasting out little tiny chunks of it.
And acrylic isnât the best for detail either, but you can do OK.
