So you downloaded an SVG file for that lovely box or gadget and then you cut it - BUT, now it doesn’t fit together.
VIDEO: https://www.youtube.com/watch?v=cLRUT059wTE
This video shows you how to edit the file with the correct thickness. Always use a calliper to find the right thickness of your material. I am using Illustrator - but the process is the same for most editing software.
