I just bought a bunch of 1-2-3 blocks to have in my studio. I am mainly going to use them to hold down large paper, and to help hold things in place for glue ups. They are very cool objects.
They came covered in oil. I soaked them in WD40, but I can’t quite get the oil off. I want them to be clean so they don’t mark paper and leave an oily film on my fingers. Any advice?
Isopropyl alcohol is what I would use. Just keep in mind that those are carbon steel and if you don’t keep a coat of oil on them they will rust from your fingerprints.
To completely remove all traces I would employ a favorite solvent - spray brake cleaner. Carburetor cleaner is almost as effective. Use that stuff outside!
Powerful and very fast action, also quick to evaporate….And very flammable.
My 1-2-3 blocks were the same. I used OilEater, rinsed, saturated with WD40, and then let them sit on a paper-towel and cardboard stack to soak up the excess.
break or carburator cleaner is the best with any grease or grime! but use outdoors and don’t smell it.
mineral spirits will work too, as well as any other stronger solvent such as varsol. (but it stinks)
keep in mind there is a reason why they are covered in oil! if you completely strip that oil (which is packing grease) those blocks will rust quickly. WD40 can be sprayed after you use them to keep off the rust but it’s far from ideal. also, if you are using these blocks on wood, the silicone in wd40 will make it impossible for any finish to later stick to the wood.
there are a few clean products you can use on steel to inhibit rust, search lee valley.
