So I put together a design for a license plate cover that I can use, but I can’t figure out how to cut out the inside of the frame design. Doing the outline cut is simple, but does anyone know how I can cut out shapes like between the frame, screw loops
, legs, and elbow?
How to do it will depend a lot on what software you’re using to design. Let us know what you’re using and we’ll have specific advice.
The cuts are pretty simple. all you need is vectors in those shapes, I find Inkscape pretty simple. You will want to start somewhere and that is as good as any.
I am having the same problem. I have an elaborate frame I want to cut but I can only get the outside cut line. The inside cutline is a very elaborate cutout and I can’t figure how to do this in inkscape. If it were a straightforward shape inside I think I could manage it, but it isn’t. I have sure cuts alot, inkscape and Gimp software
If you can upload your svg I’m sure someone can look at it.
