I bought some veggie trays (https://www.amazon.com/gp/product/B07WJ6T8HL/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1) and I want to engrave on them. Problem is, I only have the one set so can’t practice to determine the print settings. Any suggestions as to how to determine the settings?
Cheat!
Make a little signature or something separate from your design and engrave that one first with reasonable settings. That way if it’s a tad too light or too dark you can correct for the big primary job.
LOL, I like it, thanks
I usually start at a very low setting and gradually increase until I’m happy with the engrave depth. I usually start somewhere around 40% power and then go up from there.
I think the wood in the Amazon photo is Acacia wood, but I’d be a bit leary with them not naming the wood and just referring to it as “Solid Natural Wood”. I saw someone in the reviews mentioned getting different woods as well. So if you think you got Acacia wood, I’d skip to #4 below. If you’re not sure, I would go to #3. ![]()
Test a scrap piece if ya got it. (Not an option for you.)
If you know what wood it is but don’t know a good setting, you can look at something called a “Janka Scale” which lists the hardness rating of wood. You can find the hardness for the material you want to use, then find the hardness for a known wood with a similar hardness that you know the setting for and that will give you a good starting point.
When I’m in doubt, I start around 1000 speed, 270 LPI and 50-60ish power for a not too deep engraving using “vary power”. (If you aren’t sure what the different settings do, see “working with manual mode” link below.) I make sure and secure the material so it will not move and if I want it darker/deeper after the first run, I just run the engraving again. I always suggest starting very conservative with a lower setting because you can always run the engraving again and take away more material, but you can’t put it back.
Search the forum for the answer
@shop knows his stuff and I would start here if you have Acacia wood. vvvvvv
thanks. The image is sadly gone
Which image are you referring too? If it’s the one in the Acacia setting link, you can find it here. It was a link within the link. ![]()
it looks like somehow discourse screwed up my image link in that thread. let me see if i can find a picture to upload.
the good closeup i have of it is from one of my “what watch are you wearing today” pictures, but lets you see the engrave up a little closer.
