I need Glowfriend help! I cant get a file to print
ooooooo It is printing!!! I lowered the LPI then I tried shrinking it just a little! THANKS @johnse
When I ran into similar issues, I was able to print successfully by doing it in several separate jobs - split engraving into two sections, then did the cut as the third job. There appears to be a size/complexity limit to each job sent to the printer, not just on each object within the job.
I have gotten it to work by shrinking the image a bit and reducing the lines per inch. I had already tried splitting the image, but I had not reduced the LPI.
I’m so sorry for the delay in my response. I’m glad you were able to print your file! Please let me know if you have any more questions by creating a new post.
