Here. I opened it in Corel and saved it as an SVG. It should fit on the bed (I don’t recall right now what the vertical max cut is now) but if not you can move the objects closer together.
That’s great! Thank you! So much!
I’ll have to bring it into inkscape and do some separation of the parts but it’s a huge help.
My intentions are to cut the body from one color of acrylic, the wings from another and then cut a couple different brightly colored translucent acrylics to inlay in the wings where the original design intended voids.
So I did a dry run using some cardboard. I’ll need to tweak it a bit. As the description says, it’s designed for 2mm thick material and this was done on 2.8 mm cardboard. To compound the issue I was lazy and just pushed the size down in the GF UI before printing to get the whole thing to fit the bed and be done in one cut. This undoubtedly decreased the slot sizes also. Being card board I was able to jimmy the pieces together.
I suppose I should break this off to a new thread…
baller.
