When the boxes started to arrive from smallish to large to larger, I was excited. And setting it up was truly fun and didn’t stop including drilling a hole in 4" solid brick for a dryer vent. But nothing compared to when I finally powered it up, watched it come alive, the laser liquid bubble over. Then when connected it, sent a custom SVG, maple plywood with an StarWars ATAT Walker (foot only it just fn worked perfectly. I may have wet myself. not sure. Here’s a vid.
My only suggestion would be to load projects from the home page of app.glowforge.com. I noticed when you were printing the feet out, that it said you were printing the gift of good measure.
You can reset that design by clicking the ellipsis option on the top menu and select Reset Design.
One handy little trick you should be able to do (I don’t do it this way, but it should work), is if you wanted to print just the feet like you were doing, go into illustrator and select all of those components, copy and then paste them directly onto the home screen of the app. That way you don’t have to separate large, multi component files into separate files for uploading.
Yes I noticed that. I can understand it getting the name wrong if the GOGM was loaded, deleted and the feet added but why would it get the material wrong. I.e. on the left it said it was thick maple plywood but the countdown said medium draft board.
