so i have been useing a micro computer with HDD’s and SSD’s via USB3. performace has not been great cause USB… i recently upgraded the game rig so now i have a motherboard and cpu that needs to be put to new task. the thought is get all the drives on the mobo sata instead of USB.
if i had a glow forge i would make a better case but for the time being ill fabercobile something ghetto.
all in all i will have to end up having a place for 16 HDD and 6 SSD
a piece of lexan (not laser safe but was close to the right size with out me having to cut it so I went with it) to mount the MOBO to
ill add more as my project continues, with hopes of once i have this stuff mounted i will transition this thread to a fusion 360 build in hopes of a GF. in the mean time hand drilling and cutting
One question – how on earth (sorry) are you grounding it to prevent static discharge? I can’t get within 10 cm of a piece of lexan without getting shocked…
ya so I have had all lexan / plexi cases in the past and have not had a static problem. yes its a risk I just have not experienced it. also all the components carry a ground to each other via the PSU and that to earth.
so I cant give you a good answer but yes its a risk
So I used a hand layout for holes with only a tape measure and speed square so its eh. I think it would have been better if I had a second clamp but the further I got away from the clamp the more the sheets drifted. so for 1/2 the holes I had to mill them with the drill to get the screws to line up.
DO NOT MILL WITH A DRILL THIS MATERIAL WITH DRIVES RIGHT THERE.
it created a huge static load I only did it because these are not my good drives they are 400gb 300gb etc… so I don’t care what happens to them
my bit coin account only had enough in it the other day for me to order 1 controller so far so the remaining drives are still on USB and this project is a zero/low cost project so no hard cash being spent
DHL lost my SATA controller card so I have to wait like 2 weeks now for a claim to be filed and a new one sent to me so this project is kind of on hold
