This is noting special in the scheme of things. But I ran a set of these for index cards. Here is a photo, the svg file, and the settings for boxy.py. The kerf was just right for PG draft board, but might use another nudge up on the plywood. UPDATE: This worked perfect for me on PG draft board, But the PG basswood kept popping open I moved the latch size to 7 and that seems to have fixed it.
Very nice! Thanks for sharing the file!
Simple, clean, and practical!
Yeah - another box type! Thanks for sharing. Also for sharing the settings so we could tweak it for ply.
Thanks!
It occurred to me as I used the software just to do screen shots. That way I had an objective log to adjust from.
Hey, thanks!
Help, what am I doing wrong? When I right click on file I can only save as PNG and not SVG.
Don’t click on the photo or the settings image. The SVG is between them – where you see the faint outlines of the cutting pattern.
What she said
I put in a request that has helped me out a bunch. You can re-edit the setting from the url. Better yet with the greasemonkey script it will added it to the SVG file.
Here, I zipped it for you.
Index Card Box.svg.zip (5.4 KB)
Thank you. This ones works fine. I wonder if its the browser I am using, I went to another of one the free files to test(the poker chip) and it was the same,
That would be cool
great job - thanks for sharing
have to use CHROME or Firefox!!!
