Initial setup:
Connected GF and powered up.
Movement of internal units and button glowed teal.
Setup wifi and everything looked good but suddenly lost wifi from GF.
Turned unit off for 10 minutes and then back on and while there is some movement internally the button only lights when the movement occurs. Once the movement ends the light is off.
Can’t continue.
Sent to Support but maybe someone has a quick fix.
That’s normal. When you go through the set up process at some point the GF drops it’s wifi hotspot and connects through your router. After that, connect your laptop up to your normal wifi and go to app.glowforge.com
The light behavior also sounds normal.
