I want to create an outline around some selected text in inkscape. Is there an easy way to do this?
Thanks!!
This is how I do it with illustrator:
I would assume it would be similar in inkscape but I never used inkscape.
Having the latest is weird but here is the older version.
If you search, there are many threads discussing thisā¦
Thank you all, Iāll do some research. Iām doing it similar to the way wenning08 saidā¦then i want to merge it with a shape so the bottom part is āgoneā but when i highlight the two and click on union, it doesnāt do anything.
Make sure they are both plain paths, and not grouped objects.
Ungroup many times. Path/Break apart, then combine with union.
Itās especially true with text, which is a bunch of grouped shapes.
Thanks, thatās helpful. Itās hard to know what to look for to learn when you donāt know:-). I have watched several tutorials and slowly but surely gaining ground. Everyone here has been patient and helpful!
If you do the following (with the latest Inkscape), itās pretty easy:
- Duplicate the text you want to outline with Ctrl-D
- Path -> Object to Path
- Ungroup with Ctrl-Shift-G,
- Union with Path->Union
- Path -> Path Effects, then click on the ā+ā at the bottom of the Path Effects popup
- Choose the Offset path effect, give it an offset.
- Remove the fill, and give it a stroke instead.
- Then do āPath-> Object to Pathā to finalize the offset (DONāT FORGET TO DO THIS, or the Glowforge wonāt recognize it as a proper path).
Bless you:-) I have XQuart 11ā¦is that the latest version? Another question. Once i do the above, how can i merge (union) The hello into an already designed object? So i want the bottom half of hello to unite with i.e. a rectangle thatās already a vector objectā¦so the top portion of hello is sticking above the rectangle and i can engrave hello and it will be on both the long end of the rectangle and the portion you have above?
Make sense? Thank you so much!
I have no clue what XQuart 11 is. The latest Inkscape is version 1.0.
Once you have the above outline, you can join it with any other shape using path->Union (as long as that shape is also a path).
So, I could make a rectangle, like this:
Then select the rectangle and the outline (not the text), and do Path-> Union, and get this:
Which is what I think you are trying to do.
The latest version is 1.0.1, released early September. Contains MANY fixes from previous 1.0 release.
XQuartz has not been required on Mac since 1.0 beta was introduced.
Thank you all āagaināā¦i will retry. i tried exactly the way polarbrainfreeze described but i will go back and ungroup a bunch and try again.
I will see if i need to update inkscape. Obviously i downloaded it when xquart was needed:-)
Iāve spent some time in inkscape today and slowly but surely am gaining!!
Woo hoo, i downloaded the latest version of Inkscape (thanks @eflyguy for letting me know i donāt need xquart!) and followed @polarbrainfreezeās instructions and it worked like magic. Thank you for your patience with me!!
