All the svg files I designed for laser cutting have randomly all shrunk. Let’s say I designed a cut file to make a 60 mm diameter circle and when I now open the file it measures at 45 mm. I have no idea what happened. It’s happened with at least three of my files.
Does anyone know what caused this or how to fix it?
It is pretty awesome and I am definitely going to use this in the future, thank you for sharing However, I don’t think will help with my current problem
Very sure, unfortunately. I have previously cut from the same files and when I measure those pieces I get 60 mm but now when I open the Inkscape file it measures 45.386 mm.
I have already preformed that experiment. It’s actually how I figured out something was wrong. I nested my pieces on a new Inkscape file, cut it on my Glowforge and then realized the significant size difference.
If it was just one file, I would chalk it up to user error, but this has happened to multiple files that I haven’t open in months.
I am not familiar with the mathematical way to precisely resize things in Inkscape. It sounds like you do though?
I will check for reported bugs, but this originally happened yesterday and I was still using 0.92.4 and just installed the up to 1.0 hoping that would fix the problem.
I tried renaming the preference.xml file, but that didn’t fix the problem.
However, I tried the resizing method you brought to my attention and that works at the very least.
I truly appreciate all this help, I cannot thank you enough. You have turned my frustration and fear of re-doing all my files into a simple resizing process. Again, thank you.
