Wanted to post this here in case anyone hasn’t checked the site recently. Inkscape has posted a massive update for version 1.1.1 and it fixes a TON of issues! One of the nice features I’m seeing as well is native handling of EPS files(which is a bonus to me because I have several of those file types from a vector service I use)
Change log for anyone interested:
Bug fixes
General
- Thanks to the upstream fix in gtk3, pressure sensitivity works again with Windows Ink activated (Bug #1437, Making sure you're not a bot!)
- Stroke to Path works on text again (Bug #2333)
- Undoing Stroke to Path no longer loses the object’s id (Bug #2759)
- Undoing Object to Path for an object with a Live Path Effect is now possible without also undoing the preceding action (Bug #1504)
- Saving no longer leaks memory (Bug#2800)
- Startup times improved, 3.3 seconds to 3 seconds on one Windows machine (Commit 228b6a)
- Hide unnecessary warnings in terminal about optional font directories not being used (Commit 76fb99)
- Canvas no longer blurred when moving window from HiDPI to a regular display (Commit f7162b)
- Clicking selects objects again on wmii and some other window managers (Bug #2801)
- Caps lock no longer stops Delete, Page Down and some other shortcut keys from working on Windows (Bug #2496)
Dialogs
- Clicking the resize separator will toggle visibility of docked dialog (Commit 3c8683, Bug #4676, MR #2969)
- Welcome dialog:
- Transform dialog: Matrix tab no longer stubbornly insists on using display units instead of the units the user selected (Bug #2429)
- Text and Font dialog: Font features load in under a second, instead of minutes for fonts with lots of font features. More font feature glyphs shown too (Commit 0dacc4, MR #3449)
Filters
- Fast crop: Transparency is now respected when applying the
Filters → Fill and Transparency → Fast Cropfilter (Bug #2419)
Import
- EPS: Users that have installed Inkscape in the snap packaging format can open EPS files again (Bug #1406)
Export
- Optimized SVG:
Save as → Optimized SVGworks again in Linux AppImage (Bug #1738)
Markers
- Start / end markers: A bug was fixed where the path tip protruded over the arrow marker’s end (Bug #2593).
Menus
- Help menu: Now using a different set of web links to link to the documentation from the Help menu (MR #3325)
Packaging
- Snap remembers user preferences even when the home directory is not available to the snap. This may occur in LDAP, SSSD, or other set ups where there is a modified nsswitch.conf and NSCD is not acting as a proxy to snaps. (MR #3474)
- Build fixes:
- Building Inkscape works again on systems with musl libc (MR #3410)
- Building Inkscape works again on NetBSD (Commit 1029bb, Commit bfb81a, Commit 160dc7, Commit e12966)
- Building Inkscape works again on FreeBSD (Commit 06b143)
- Building Inkscape works again with GCC 7 (Commit 3d8be5)
Templates
- All templates generated from the ‘Welcome’ dialog now use a document scale of 1, making it easier to hand-edit documents created using them (Bug #2728)
Tools
- Measure tool:
- Settings for font size and precision for the Measure tool work again (MR #3343)
- Position dialog moves handles to the right place again (Commit 1fcc33)
- Measurements no longer reset on right click or tool switch (Commit bd9349, Commit 341a0e)
Crash fixes
Fixed a crash when …
- … using a grid with the Document Properties dialog open on Windows. This also fixes a memory leak on other operating systems, that did not necessarily lead to a crash. (Bug #2585)
- … trying to copy an object without ID (Bug #2714)
- … stroke to path applied on paths with no area, fill, stroke, or markers (Bug #2502, Bug 2572)
- … entering a space character in the ‘Attributes’ field of the ‘Clone Original’ LPE settings dialog (Bug #1709)
- … closing a window while the filter editer dialog is floating and a filter is selected (Bug #2753)
- … pasting 3D boxes when the 3D box tool is active (Bug #2741)
- … multiple objects selected for spray tool in single path mode (#2740)
- … quitting in command line or when opening windows if done before window fully loads (Bug #2776, Bug #2487)
- … Homebrew or MacPorts used and XDG_DATA_DIRS is not defined (Commit 1a6c62)
Extension bug fixes
Translations
The following UI translations received updates:
- Brazilian Portuguese
- Catalan
- Czech
- Polish
- Russian
- Slovenian
- Traditional Chinese
- Simplified Chinese
