Wow, it’s been a long time. Trey, remember? No, it’s ok, I’m bad at names too.
So, the latest in my series of gift valet trays, I decided to add a little directionality to it by embellishing the front with an inlay. This is for someone who just celebrated her 40th, so a little inscription seemed to be in order.
Let’s dig in.
- Overall dimensions (internal) are 6.5" x 8.5"
- All wood non-PG solid hardwoods in 1/8"
- Liner cut from chrome-free leather from Tandy
- Base is 2 layers of 1/8" baltic to give it heft
- All exterior wood surfaces are finished with wipe on satin polyurethane. The only part that is not finished is the inside of the base so the leather can be properly glued in place.
- All wood sanded to 600 grit, it brings out the shine
In terms of construction techniques, search for “@evansd2 tray in:first” and you’ll find my other tray posts that get into a lot more detail about kerf compensation, foot installation, and overall glue-up.
The basic design is something I’ve explored and posted about before, contrasting corners with complex butt-jointed curves. I’ve settled on dark corners, it makes the finger joints nearly disappear.
I design the trays and the inlay in this case to be viewed from the outside of the tray. That being said, it looks just as nice from the interior, albeit a bit cut off by the leather/base. With inlays like this, (I call this a “hero inlay”) it’s important to put your best foot forward. As such, you should take care to ensure that all your hard corners are eased before you cut anything, to prevent unsightly overburn “pocks” in the hard corners.
Figured walnut, Figured maple, Padauk, Cowhide
The padauk has nice chatoyancy to it, which really glows when lit properly, This is a more accurate color representation. It shimmers a bright almost metallic orange. It’s my favorite aspect of padauk, and very difficult to convey via the forum.
Figured walnut, Figured maple, Padauk, Baltic birch ply
A simple engrave is the way to go here. One’s 40th is a minefield.
Figured walnut, Figured maple, Baltic birch ply, Rubber Feet, Stainless steel screws
The corners are new shapes, and I shifted their aspect ratios so that they are oval spirals, I’m pretty happy with the end result. This is also your best look at the light figuring in the maple, it has a nice gentle waviness to it, it shimmers and changes as the light moves.
So? Not much more to add here. Assembly went smoothly, no real mistakes to learn from, I’m fairly dialed in.
