Is there an available assembly instruction guide for designs in the catalog?
When you are on the dashboard to the right on the top bar you will see 3 vertical dots, if you click on that and select design details you should find the instructions there as well as the spot to reset the design if needed
Great! Thank you for this information…
Np hope that was what you were looking for. have a good day
Some designs are missing instructions. If so, post over in Problems and Support so staff can confirm and correct.
Noted. Thank you.
Thank you for the info cuz I really was wondering how you was supposed to assemble of these designs!
Ok! Also I just opened the space ship and although it has assembly instructions, there is absolutely no settings instructions. How am I supposed to know what to cut, engrave, etc… strange
ok moving…thanks
Support doesn’t browse the discussion forums. You need to post these issues over in Problems and Support so it will create a ticket and they will see it.
