I am trying to take inventors parts .ipt files and import/export them to save them as .svg files so that I can cut them with the glowforge, any ideas
Can inventor save natively to .pdf? Because Inkscape can open the .pdfs if you want the .svg - or the can print from .pdf
Evidently that is a good question because there isnāt a direct way to make SVGs. That whole getting from 3D to 2D seems a lot more complicated than it should. Interoperability issues are the bane of my existence.
This post seems to have a pretty good break down of it that allows you even to designate colors for the lines. Seems a bit clunky with all the cutting and pasting, but you do get a PDF.
http://www.informatik.uni-bremen.de/agebv/lasercutinventor
Inkscape can open 50 or more file types, including AutoCAD (dxf)ā¦ Find something your app can save to that matches.
Have you tried searcing the internet in general for converters? I have one that works for ai files so i can open them in Inkscape and save as SVGs (before someone says otherwise, maybe other versions of Inkscape will open ai files, but the one i have loaded does notā¦).
So Iām sure there are converters out there that will take the ipt and let you open in Inkscapeā¦
You can export DXF files from Inventor which Inkscape can open.
