My wife asked for a stand that would allow her to stand her IPad up vertically but allow her to charge it while using it. She wanted the button on the bottom. I made her two one practical and one a little more whimsical. Both done in Inkscape.
Nice design!
They look great!
I don’t see the file. Did you mean to post this on Made On A Glowforge? If so, I can move it for you.
I am having a problem loading the files. ?
IPad Holder.pdf (5.1 KB)
IPad Holder-1.pdf (12.8 KB)
I posted them as pdf and that worked . I tried both Inkscape svg and plain svg and neither would post.
Thank you!
The SVG files are there in the original and in your repost. They’re just really small, you can edit the post and change the size if you like.
I do not know how to make them larger. Any help in doing this for future reference.
IPad Holder|20x12](upload://rOUIsQ7afZyOvlWyPBa3iPvp3C4.svg)
When you upload, where it says 20x12 just above here, change those numbers. At the top I put 200x120 and just under it I made it 400x240 (being lazy, I just multipled by 10 and then doubled to keep the dimensions in the appropriate ratios)
That’s how I usually do it.
Except being lazier, I tend to stop after the “multiply by 10” step ![]()
I’ll use the “illustrative purposes” defense
Thank you I will do that in the future.
