I have some IPI Laserables 1/16th plastic sheet. I am certain this is a dumb question because “laserables” is in the description but it still makes me nervous:
usually when its marked ‘laser safe’ they are talking about running it thru a ‘laser printer’ like an HP. . But I assume if it can handle the hot rollers of a laser printer, it should work well with the hot ‘blade’ of a Glowforge…
Johnson Plastics Plus means a laser when they say a laser - not an HP laser printer. I think you should look at the provided link before making an assessment.
Yes, laser safe, and does a neat job. I do find running a very fast engrave over the first will clean up leftover material. Without it you sometimes get a “fuzzy” look to the engraved areas.
I saw that, but the comma tripped me up and I thought that meant rotary engravers only. I guess there aren’t rotary lasers. Figured it was a dumb question but just wanted to double check
It was not a dumb question. It is always a good idea to be safe, and if you are worried about a material seek more information. Rotary engravers are a thing, and commas are important.
