Is GLOWFORGE SPARK a new machine?
Earlier today I was doing some research about trademarks and I came across these pages.
Did someone make a mistake by capitalizing every single letter in the name?
I wonder if this is a new machine.
You wouldnā€™t want to spoil a product launch if it is, right?
Lots of time and money go into those, making them happen in a coordinated fashion at the time the company chooses.
Weā€™ll all find out together when they decide to announce whatever Glowforge Spark is.
Companies register names and product concepts all the time, as you have discovered. Sometimes it means a new product is in the works, but often it just means they have an idea of a product and want to protect the name. I think Apple has a ton of registered names and concepts.
To be fair, trademarks are public domain, so it wouldnā€™t really be spoiling anything
I found some leaked pictures of an early prototype.
Spark is a machine for sale on the Glowforge website. Smaller version of the aura
It is a new machine. Itā€™s listed on their machines for sale page. Smaller version of the aura.
Oof the learn more page is 404 error.
interesting that they list ā€œsandpaperā€ as a material it can cut. seems like an odd material to choose.
and they list titanium and aluminum as engravable. which isnā€™t technically accurate.
still a 6w blue diode, cutting area 8.5x11, but can hold 12x12 material.
:crazy_face: :smile:
They did the same for the performance models despite it but being exactly true either. Clearly itā€™s language okā€™d by the lawyers. I remember long threads back in the day hashing that over and over!
Now that itā€™s no longer a leak, the FCC had published internal and external photos of the Spark from its RF emissions testing last month:
Joann almost leaked it too. They added a Glowforge Spark category to their website last month, but hid the machine from appearing in the category until today:
Iā€™m excited about one thing: Itā€™s much cheaper than I expected. Thatā€™s a crazy price point for retail.
Iā€™m a little disappointed by two things:
  1. The Spark having an even smaller work area despite the same bed size. I figured itā€™d just be an Aura minus the passthrough slot.
  2. I was hoping there was going to be a second laser head option with more than 6 watts that could fit either of the diode laser siblings.
The signs I misread that led me to hope for that:
  1. ā€œGFD Basic Buttonā€ and ā€œLASER HEAD, PROā€ labels on two of the PCBs in the FCC photos.
  2. The newly introduced higher speeds available only when using manual settings on the Aura. I was hoping they were added because new Proofgrade settings would use those higher speeds in combination with a 12W-20W head.
Looks like they didnā€™t change anything about the rails and bushings from the aura. I wonder if weā€™ll see the same avalanche of ā€œmy design skips in the middle of the jobā€ complaints as we do with the aura?
OK, weā€™ve just been cleared to talk about this. Yes, itā€™s real. Just smaller than the Aura. Same LED laser head. No one who I know is beta testing, has experienced any X axis motion problems.
Without a Draftboard like material capability, itā€™s a non-starter for me. I need a rigid, easily paintable (especially with markers), material. Has anyone used ā€˜chipboardā€™ in their Aura?
On Amazon thereā€™s 2.5mm, 2.2mm, 1.7mm and 1.27mm variants.
If the 2.2mm or 2.7mm worked, and it didnā€™t char 1/4" on either side of the cut, that would likely be suitable. Probably going to be smoky, but thatā€™s what exhaust fans are for. :slight_smile:
Thanks!
-Edit- YouTuber does a review of the Spark cutting the light Cherry. So should work fine, as long as the Chipboard isnā€™t scorched earth after cutting.
Does it have Snapmark? I really miss that feature. Seems like a given for the cricut and silhouette crowd.
Just wondering if the new mechanism would allow for consistent snapmarking.
Have not but if no one pipes up Iā€™ll give it a try as soon as I can.
I have cut mat board and watercolor artboard (each about 50 mils thick) in my Aura with no trouble, and less char than I see in my Pro. I would assume the Spark would do about the same as the Aura.
