Hadn’t thought of the plotter/vinyl cutter option. That feature is starting to make sense to me.
That would be so amazing. I have considered picking a cutter up once I finish paying off the Glowforge but space is already an issue in my craft room.
there are parts of the head that will need to be clean such as the lens and at some point the lens may need to be replaced. you are creating dust and smoke as you engrave. and the laser puts energy that takes the form of heat and that passes through the glass lens they can be marred by the beam and heat may cause fractures in the lens having it removable makes it easier to do things like clean and or replace the lens . my Large laser at work has a removable head, as at least once a week we clean it completely.
That makes a certain amount of sense – even if it’s not a consumable, we would all be happier cleaning the heading without being head and shoulders deep inside the machine. (Although I do wonder a little about the repeatability of head position after removal and replacement. You might lose a few mils that way.)
Doesnt on my Epilog at work.
Nope! You can’t see the air assist in those pictures, it rides below the gantry.
That!
Ah okay. From what I remember from Makerfaire it was small grey 40mm fan of some sort?
This looks like some sort of espionage research photo. awesome
Shhhh!
I think it needs more red arrows, grainy close-ups, and Illuminati insignia.
But it’s a great start!
I took it off and put it back on a few times as I was doing the setup pics. Turned on and off power in between as protocol. It re-seats itself very easily and is firmly stuck in place and yet can be extracted easily. The head reoriented itself as required.
It may be opalescent because the lenses are an amazingly unique hue, but it definitely won’t obsolesce in the “Hidden Persuaders” way. As a piece of machinery, it looks way sturdier and tight than anything I’ve encountered. I recently took apart a 2D laser printer and had a gander at the spinning reflector and the lenses and laser unit. I understand that the G forces of a moving Glowforge print head are quite different from a stationary HP Laserjet 5000N, but my HP is still humming after fifteen years and I’ve not done anything with it.
That is not an engineer’s assessment, but an observation of someone who has been taking apart gizmos with motors and lights since since I was 5. It just feels like it’s in for the long haul.
And if there is damage, it can be serviced easily enough.
You won’t be cleaning the lens. It is sealed inside the print head. There is a window that protects it and that is cleanable easily. Go
- Rich
No, that’s the purge air - positive pressure that keeps the lens clean.
Is the source of that positive pressure highly filtered air, or just ambient air?
I see. They are normally the same thing. I.e. the lens is inside the air nozzle that blows high pressure air through the cut. The picture labelled Fabregé Egg seems to be the underside of the head so it doesn’t look like Glowforge even has a nozzle under the lens.
