I’ve been here before with the nightlights, but true to form, Walmart pares things down to minima form and function. It’s an always on light, so not quite as good as the ones with the sensors.
The bottom clip is different. Seems to have the same three slots (perhaps they don’t want to change the die), but it only needs the center one.
Blue LED is a nice touch. Smaller. I was a bit apprehensive about buying them because They looked like they would be welded together instead of screwed as the ones I had used before.
No problem. Glowforge thick acrylic is a perfect fit. I just recut the bottom edge and joined it to what I had made before.
So if you are looking for a project for a nightlight, this is a no brainer. Here is the file for your enjoyment. The acrylic reflector just slides out. The original seems to be polycarbonate.
