A jewelry box for a friend’s partner who just changed their name. Walnut and aspen with Bloodwood monogram. Made with 1/8" hardwood (thus the screw backing bits in the lid/box) 7x10 inches. 5 inches deep with the lid.
Beautiful inlay work!
Just gorgeous!
Nice work.
I assume your lid is 2 layers deep? Or did you use veneers for your inlay?
Mind sharing your source on the aspen? I like the uniformity, might be a fun alternative to my go-to maple for light inlay work.
Yes! It’s 1/8" deep, backed with 1/16" aspen (why the underside of the lid is brighter).
Happy to share my source, since I learned about it on this forum! https://ocoochhardwoods.com
Ah I either didn’t know or forgot Ocooch does aspen. I’ll keep it in mind, their stuff is pretty high quality.
How’d you finish the wood?
That piece looks really great! Are you going to make trays to go inside it?
I love the inlay and the grain! great work!
A ton of sanding and then tung oil.
I offered, but friend said she was going to get a premade insert for it.
I’m in love with the chatoyance in the figuring on the front. Just lucked out.
I had originally purchased 600 & 1200 & 2000 grit sandpaper for sharpening carving tools but discovered that on hard woods that will not have a layer of lacquer on them the result is amazing both in look and feel
Yep! A lot of what I do with wood involves stuff that isn’t going to get a varnish/poly coating. So I sand it to within an inch of its life and get some amazing shine. Depending I’ll go up as high as 7 or 10k grit.
Do you do that manually? Your box is just beautiful. I wish I had the patience for sanding and finishing, that’s where I lose interest and just want it to be done already
It is like knitting. It does not take the attention that other stuff might. So as I need to let the pain in my back go down I can watch a movie and also sand at the same time,
The top is very intricate and gorgeous. Excellent work.
Lucky friend - that is a beautiful piece!
Lovely finish.
This is a beautiful piece of work. I wish I could “admire” the wood with my fingers.
Omigosh…that is perfectly lovely. What a wonderful gift.
