Been playing around engraving some stamps for leather work and was starting to get some good results with some fine details. So I ended up making these, just a greyscale depth map and the right settings. afterwards I coated them with flat white paint. Dimensions 3.7"x6.7"
Here is a quick video I made so that it looks like the sun is setting over the terrain and through it looked neat, it almost disappears as the end because it is such a thin coat of paint on only on the one side of the clear acrylic.
Also tried stamping them into leather with limited success, and also forgot to make it a negative for the stamp so it all came out wrong.
Also making some more Christmas ornaments this year but combined the settings i have for marking tiles to wood And getting some decently detailed photos :). The dimensions are 5"X3.65"
The fiddling i did was pretty specific to that photo i posted but these are the settings i used under, filters-color-grayscale. You can grab the pic from above and apply these settings. Its a balance between all 4 variables and hard to explain.
The one spot it fails is when the height map photo goes to white at the very highest and this filter ends up making those spots slightly lower than the surrounding.
