Right!
I had some time to get my machine through the motions mentioned above.
- Turned off the glowforge.
- I took out the honeycomb tray and checked for debris
Squeeky clean (as it’s not heavily used because of all of the above)
also very clean and nothing to note.
No debris on where the lid rests.
Lid closes and rests very nicely
Surface is level
and so is the machine
Turned my machine back on
Took out the proofgrade medium draftboard from my last test. It’s still full size board. Funily I have the most problems cutting through in the top left corner but just in case I placed another design in the bottom right corner. (Traditionally the furthest away of the laser source) Job started around 12:16 today tuesday 28th september.
6+7. Without touching anything I took some screenshots:
Additionally; and I was not expecting this.
Both cuts did not cut through the proofgrade material. Which is weird as the cut from september 2nd did go through.
Now on to the other important stuff. At least to me
A cut from today. Still the same batch of acrylic. On the digital angle gauge. 84.5º. That’s a full 5.5º off of 90º
I picked up a piece I had made on my previous glowforge. It used to be 87.8º
This is what that kerf looks like freshly cut. You can make out that the plastic layer underneath is not cut through all the way. It used to on my old machine on faster settings. I brought back the speed on this machine but it is still not cutting through well enough. (153/full/auto)
Now this design used to be very stable. Because off the new kerf offset I had to account for another 0.2mm kerf in the design. Put together the whole thing is still very wobbly. on account to how much more kerf and diagonal offset there is in the cut. I can’t sell this.
View post on imgur.com
