Kerfinator and how to use them
When talking about kerf and Fusion 360 I have mentioned a couple of times that kerf is somewhat subjective and the best way I have found to adjust for it is to make a small object that uses the same type of joint as what I plan to use for a larger project.
To use this sort of thing, install DXF for Laser from the Fusion 360 store this will allow you to adjust the kerf quickly and experiment until you have what you want.
The kerfinator I am posting the link to is for box joints but you can use this concept for slot together parts or any number of other joint types. The concept is to simply sacrifice a very small bit of material getting the kerf the way you want it before committing to a large project.
To use this simply open up the parameters box and enter the exact thickness of the material you are using, then click okay. Now click on a face of the model and activate the DXF for Laser plugin. The plugin will bring up a dialog box like you are used to seeing. Input a kerf value and click okay. Do the same for the other part.
Convert the two DFX files to a single SVG. Cut these on a piece of scrap of the type you want to use and test fit them. If you like the fit, you are done. If not, try again adjusting in the direction you want to go. A larger number for a tighter fit, smaller for a looser fit.
Now you can integrate this kerf compensation into a parametric model or simply use DXF for Laser to export faces using the number you came up with.
.21mm is a good starting point for the :proofgrade: plywoods
Seems to be a problem with Autodesk taking this public so here it is in a zip. Sorry about that. Removed link as this is not going to happen. Please use the zip below.
kerfinator.zip (118.1 KB)
As always, let me know if there are problems or if you find this useful.
When I click on your link to “Box Joint Kerfinator” I get the following message.
This project is not public yet. You are not authorized to view it.
I can’t get to it either. :frowning:
I don’t know what is wrong at Autodesk, perhaps me not finding just the right places to click. But anyway, I edited the above and added it in a zip.
@Jules
@Just-Maken-It
@ anyone who tried and didn’t get it.
Oh, thank you kindly dear sir! :kissing_heart:
Yeah, that’s pretty handy…just printing a small sample without having to build it first…aces! :slightly_smiling_face::+1:
I took a look at the two DXF add-ins that you and @chris1 recommended yesterday - each seems to have it’s plusses and minuses, but both look good…
The Save DXF for Laser brings over smooth curves instead of segments and gives a kerf adjust option, but the segments are not joined in the DXF. Not a problem, I’ve got a Concatenation add-on for AI that links them up with a click or two.(RJ Graffix)
The Shaper Utilites add-on joins everything into one shape and does a direct to SVG export, which opens fine in the GFUI, but it’s still got the segmented curves and no KA.
Either one is value added though, so it’s just whatever folks want to use it for. :slightly_smiling_face:
I’ll have to give this a try this evening when I get home.
Thanks!
That looks very handy for DXF files all right. Thanks for sharing! I’ve been using Tinkercad to design boxes, and it produces SVG files directly. I followed the Inkscape stroke-to-path method that others have mentioned, but it’s time-consuming to do all the steps for each shape, so I wrote a little Python script to automate it. You all are welcome to use it however you like! GitHub - wbain/kerfer: Utility for adjusting SVG cut files to account for kerf.
