Did you have to set up an API to download?
With SnazzyMaps you should just need a free account. A free account allows you to download up to 10 .pngās a day, which isnāt too restrictive if youāre just using it for hobby projects.
I see it now ⦠I was looking at HTML and not downloading an image.
Thank you!
I always lived in suburbs, except at college⦠so⦠my maps would be boring!
Understand that. Few roads my way. Used a GPS for directions home a few years ago. Said āNo route foundā
Donāt sell yourself short! Depending on where you went to college, you probably have a map worth making. Even the suburbs have maps with a grand story to tell - you may just need to dig a little deeper. Check out public data sources like neighborhood boundaries, zoning areas, or even the water/gas/sewer lines.
As an example, hereās a map of the University Iāve been lucky enough to teach at this year.
Iāve separated buildings, athletic facilities, athletic fields, and streets into their own layers that I plan to⦠well⦠layer for effect in the final product:
I intend to post a tutorial + lessons learned once I make the cuts. PSU fans, feel free to reach out for the .svg ![]()
I made a few maps this week myself, trying out different styles
The hardest part is actually framing them on the cheap⦠having some trouble with it⦠the wood is a lot thicker than a photo so they donāt fit well in photo frames, I have to take out the glass or I canāt get the back board back in, etc⦠Any advice on finding something deeper that works well for wood art but cheaper than custom framing?
The float frames I linked above work nicely. They come with two layers of glass and a ~0.6ā spacer. Framing two layers of 1/4ā draftboard or one layer + a cardboard backer worked for me.
Did the link possibly change when you published it? This link in the first post is still going to a page not found.
If you go to the site, choose āmake a mapā then in Styles search āglowforgeā youāll find it.
Sadly, thatās not my template. I donāt think the admins of SnazzyMaps have got around to approving my template yet. The 48 hour turnaround is what they say on the site, but I wouldnāt be shocked if they have a little bit of a backlog to work through.
Searching either āGlowforgeā or āLaserā will produce plenty of good templates though!
Wow, nicely done! Iāve been working on some maps myself. Hereās one that I made from some thick posterboard for some friends in San Diego.
Iām in the same boat with framing these and trying to find decent frames for a decent price. Itās easy to find cheap packs of frames on Amazon but they donāt have much room. Iām considering a custom order from FramesUSA and getting a brad gun to place the flat holder things behind the artwork.
*Anybody know the actual name of those bendable nail/brad holder things that go in the side of frames and hold the artwork in?
they are called Points (or sometimes tabs). You can buy a Point Gun/Driver (or Tab Gun) that works like a staple gun. You can also buy a Point Driver (or tab driver) that works like a vise.
For softwoods, you can also look for Glazier Points that are inserted using a putty knife.
point driving gun from Amazon (just an example, not an affiliate link, and I have never used this model/brand)
https://www.amazon.com/Logan-F500-2-Point-Driver-Elite/dp/B003BMFOJQ
edit: I see that this same brand is sold by Lee Valley, so chances are itās a decent tool.
Lovely! What did you use for the masking? Iām assuming the paper did not come with a protective layer.
Hereā¦this is the good stuff⦠
Nice work!! Love the maps!!
Had Lowes make a delivery to my parents a few years ago and it had them turn less than 1/4 mile from the house (you could see it from the intersection) and go an extra 2 miles and go through a field
. They actually did too, then said they were worried Deliverance was about to turn into a movie of fact rather than fiction.
Howdy all! I finally posted my tutorial. Itās under the āFree Laser Designsā category for now. Check it out if you want to make your own maps!
